Importing data from Toggl Plan and Toggl Track to Toggl
You can easily transfer your data from Toggl Plan or Toggl Track into Toggl 2.0. This article explains how the importer works and walks you through the available import methods.
How to import data
You can kick off the import from any of these three entry points:
  1. Top banner.
  2. Import data button in the side navigation.
  3. Settings → Data Import.
Select the product you would like to import from, your desired workspace(s), and click Import data.
Importing from Toggl Plan
  • Import all time data from Toggl Plan to Toggl.
  • Team admins can import all data for their team, including team members. Users who have not yet used Toggl will receive an invite email.
  • Import projects, tasks, status, teams and team members.
  • Task notes become the description in Toggl tasks
  • Task comments are imported but not displayed in Toggl as yet.
  • Task checklist items becomes subtasks in Toggl
Importing from Toggl Track
  • Import all time data from Toggl Track to Toggl.
  • Choose whether to import data for your entire workspace or just for your user account.
  • Choose whether to add Toggl Track workspace members during the import. If skipped, their data still comes over — they just won't get Toggl access until an admin grants it later.
What's currently supported:
Data What's included
Clients Name, archived state
Projects Name, active/archived state, private/public, billable status, color, client, fixed fee, estimate, and start/end dates.
Recurring projects
Imported as recurring templates in Toggl 2.0 (weekly, biweekly, monthly, quarterly, yearly)
Tasks Name, done/archived state, time estimate, assignee, project
Tags Name. Created or matched, then assigned to each imported time log that uses the tag.
Time entries Description, billable flag, start time, duration, owner, project, task, and tags. This includes zero-duration entries
Members Activated in Toggl 2.0 with no invite email required. Track workspace admins become Toggl 2.0 workspace admins, Track Analysts and Project Leads get the matching Analyst or Project Lead access level (see below), and everyone else becomes a Member. People who were already in the Toggl 2.0 workspace keep their current access level.
Default visibility setting Toggl Track’s default project visibility (whether new projects are private by default) becomes the workspace’s Default visibility in Toggl 2.0, under Admin settings → Workspace setup. In Toggl 2.0 this setting applies to new projects and new standalone tasks. Imported projects keep their own private/public state. Needs a plan with private projects (Starter or higher) and an importer who can manage workspace settings; otherwise the setting is left as it is and the import shows a warning. Full-workspace import only.
Project templates Each active Toggl Track project template is also saved as a Toggl 2.0 project template, with its tasks, members, rates and alerts. The original stays as a regular project too, so time tracked on it keeps its place. Archived templates come over as regular projects only. Needs a paid plan and permission to manage templates; otherwise templates are skipped with a warning. Running the import again doesn’t duplicate templates, and a template you deleted in Toggl 2.0 isn’t recreated. Full-workspace import only.
Project groups Become teams on the project (full-workspace import only)
Project members Per-user project access is preserved; Toggl Track project managers become project managers (full-workspace import only)
 Billable rates & labor cost  Imported at all four levels — workspace, workspace member, project, and project member — including full rate history (not just the current rate). Recurring-project rates are preserved. See Billable rates & labor cost below for details.
Timesheets and approvals Needs Premium in 2.0 and approvals on the Track plan. Only weekly setups, and monthly setups that start on the 1st, come over. A rejected Track timesheet arrives as “changes requested”. Slack reminders aren’t imported.
Required fields The setting is imported to Toggl 2.0
Member working hours
Saved Reports These become saved views. Custom reports aren’t imported, and a report whose filters 2.0 can’t show is skipped with a warning.
Workspace and project alerts. Task alerts aren’t imported.
Tracking reminders and rules A group reminder goes to the group’s current members only.
Team Lead role  For imported teams.
Analyst and Project Lead roles Track Analysts and Project Leads get an Analyst or Project Lead access level in Toggl 2.0 with similar permissions, instead of Member. These two access levels exist only for members imported from Toggl Track: you can’t give them to anyone else, and if you change a member to a different access level you can’t switch them back. See Access levels in Toggl.
The importer brings over billable rates and labor cost at all four levels Toggl supports: workspace, workspace member, project, and project member. Full rate history is preserved, not just the current rate — including rates on recurring projects.
Dates. Toggl Track stores rate periods as calendar dates in the rate creator's timezone, with an exclusive end date. Toggl 2.0 end dates are inclusive, so the importer subtracts one day to keep the same coverage.
  • For example, a Toggl Track rate running [2024-01-02, 2024-04-02) becomes 2024-01-02–2024-04-01 in Toggl 2.0, without losing or gaining a day.
  • A Toggl Track rate with no start date (open from the beginning) is imported with a start date of 2006-01-01 — the earliest date the importer supports.
  • A missing end date stays open-ended.
  • Time-of-day is not retained, since Toggl rates are date-only.
Currency. Amounts are converted using the resolved currency's smallest unit (e.g., USD/EUR to cents, JPY with no decimal places, BHD/KWD to three decimal places, CLF to four). Amounts more precise than the currency allows are rounded, and this is noted in the import warnings. Currency is resolved project → workspace → USD for project-level rates, and workspace → USD for workspace-level rates; falling back to USD is flagged as a warning.
Re-imports. Running the import again keeps rate history in sync — changed, added, deleted, or restored rates in Toggl Track are reflected in Toggl 2.0. Re-importing unchanged data makes no changes. If any part of a rate timeline can't be converted, the importer leaves your existing Toggl 2.0 timeline as-is rather than replacing it with incomplete data.
Permissions. The Toggl Track user running the import needs permission to view both workspace rates and member labor costs. Without it, the import fails rather than importing partial financial data.
Limitations:
  • Task-level rates aren't imported — Toggl has no task-level rate concept, so these are skipped with a warning.
  • Rates tied to a member or project that couldn't be matched are skipped with a warning.
  • Invalid, negative, or unrepresentable amounts, and invalid date intervals, are flagged with a warning and that rate's full timeline is left out.
  • Overlapping rate periods in Track are normalized, since Toggl doesn't allow overlapping intervals — the newer Track rate wins, and this is reported as a warning.
  • Deleted rates, projects, or membership relationships in Track aren't imported (archived projects are still eligible).
  • Historical fixed fees aren't imported — only a project's current fixed fee comes across, since that's all Toggl 2.0 stores.
Things to keep in mind
  • This is not a live sync. Changes made later in Toggl Plan or Toggl Track (e.g. edits, deletes, re-assignments) will not reflect in Toggl. You can enable a live sync with Toggl Track after completing an import — learn more here.
  • Import is available at Workspace level only. You cannot choose specific projects. Everything in the selected workspace is imported.
  • All time data is imported to Toggl 2.0 up to the first 30-month gap. For example, if your workspace has three years of data, a two-year gap with no data prior, and another year of data before that, only the first three years would be imported in this scenario.
  • Recurring projects: the current period starts on the project's actual start date in Toggl Track, so backdated contracts (for example, an annual contract that began last October) keep their true period boundary and run forward from there. Projects with custom or irregular recurrence aren't supported yet — these import as normal, non-recurring projects.
  • Fixed fees: Only the project's current fixed fee is imported — historical fixed-fee changes are not brought over.
Deleting imported data
  • Admin Settings → Data import → Import runs → Delete imported data
  • It removes the time entries, tasks, projects, clients and tags that run created, plus the saved views and alerts it imported. Anything still used by other data is kept.
  • It can’t be undone, but you can import again.
  • Toggl Track sync must be off first, and you can’t delete while an import is running.
  • Project templates the import created are not removed. Delete them from Manage templates on the Projects page if you don’t want them.
What's not imported yet
A few areas of Toggl Track data aren't covered by the importer yet, though support for these is in progress:
  • Goals
If your workspace relies on these, plan to re-create them manually in Toggl 2.0 after import until support is added.
